Hasselblad100
Feb 28, 2021Aspirant
Orbi RBR50 Vigor 130 and Sky UK
Hi I'm having issues with stability of my Sky Hub throughput so have decided to try and go with a 3rd party modem (Vigor 130) and the RBR50 in Router mode in order to dump the Sky Hub altogether ...
Feb 28, 2021Guru - Experienced User
Let the modem handle the PPPOE connection. All you need to do is to connect the Orbi RBR to the modem.
Review the modems user manual on how to set it up and connect a router to the modem.
- Hasselblad100Feb 28, 2021Aspirant
Sky UK uses MER/DHCP 61 for VDSL2 authentication. Does the Vigor 130 do that?
- FURRYe38Feb 28, 2021Guru - Experienced User
Something to ask the Mfr about.
