gooders
Dec 06, 2019Aspirant
Orbi RBR50 VLAN setup
Hi there I'm trying to connect my Orbi RBR50 to my new FTTC NBN connection (with TPG). I need to change my VLAN settings to do this. But when I try to follow the instructions for this in the ma...
Dec 08, 2019Guru - Experienced User
What browser are you using? Try a different browser?
gooders wrote:Hi there
But when I try to follow the instructions for this in the manual...
"Select ADVANCED > Advanced Setup > VLAN/Bridge Settings"
There's just one problem...there's no VLAN/Bridge Settings tab there!
I've looked all over for it, but can't seem to find it.
Any ideas please?
Thanks
gooders
Dec 08, 2019Aspirant
Was using safari, but changing to chrome the option is now there!
Thanks v much for your help!
