Sebologic
Nov 15, 2019Follower
ORBI RBR50 Voltage question.
Hi, im buyed an Orbi RBR50 from USA and im in Argentina, the voltage here is 220v, and the equipment have 110v. my question is, can i connect it to 220v or i need a transform from 110v to 220v. p...
CrimpOn
Nov 15, 2019Guru - Experienced User
I believe the concensus is that the adapter is rated for 110-240v. There have been numerous posts on this topic.
Amazon sells replacement power adapters that clearly state multiple voltages: https://www.amazon.com/Charger-adapter-Netgear-A010101-A010201/dp/B07FCBDN1V/ref=pd_sbs_147_1/140-6492656-3100122?_encoding=UTF8&pd_rd_i=B07FCBDN1V&pd_rd_r=fdac94e3-c0f1-4efa-880d-2c3718c5195c&pd_rd_w=WURB3&pd_rd_wg=TrdVm&pf_rd_p=52b7592c-2dc9-4ac6-84d4-4bda6360045e&pf_rd_r=6H1F618MR7G1KG5RB8QV&psc=1&refRID=6H1F618MR7G1KG5RB8QV
