Sebologic
Nov 15, 2019Follower
ORBI RBR50 Voltage question.
Hi, im buyed an Orbi RBR50 from USA and im in Argentina, the voltage here is 220v, and the equipment have 110v. my question is, can i connect it to 220v or i need a transform from 110v to 220v. p...
michaelkenward
Nov 16, 2019Guru - Experienced User
I have a USA style Orbin working in the UK, another civilised country that uses 240 volts.
You might like to read this too:
ORBI RBK53 Region Change - NETGEAR Communities
You may want to change the wifi region on your Orbi NAS.
