steve04KU
Jan 28, 2020Aspirant
ORBI RBR50 w/ 2 RBS50 Satellite issues:
I have an Orbi RBR50 daisy-chained with 2 RBS50 satellites. Neither satellite is connected by ethernet cable. Only wifi. Connections from the Router to Satellites are 5G and GOOD. Is it normal that w...
- Jan 29, 2020
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATAlso having wifi signal broadcast from modem can cause interference issues as well.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopPlease disable ALL wifi radios on the upstream router...Give one of the above suggestions a try.
CrimpOn
Jan 28, 2020Guru - Experienced User
Both satellites are the same, or is the "far one" lower than the "near one"?
How is speed being measured?
- steve04KUJan 28, 2020Aspirant
Satellites are setup in A-B-C Daisy-Chain.
A ---> B---> C
A Orbi router (ground floor office, hardwired, acting in router mode)
B satellite (ground floor kitchen)
C satellite (2nd floor play room)
Speedtest.net app for speed tests via iphone 11 or ipad.
