steve04KU
Jan 28, 2020Aspirant
ORBI RBR50 w/ 2 RBS50 Satellite issues:
I have an Orbi RBR50 daisy-chained with 2 RBS50 satellites. Neither satellite is connected by ethernet cable. Only wifi. Connections from the Router to Satellites are 5G and GOOD. Is it normal that w...
- Jan 29, 2020
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATAlso having wifi signal broadcast from modem can cause interference issues as well.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopPlease disable ALL wifi radios on the upstream router...Give one of the above suggestions a try.
Jan 28, 2020Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
Armor, Circle, Daisy Chain needs disabling for ethernet connected RBSs, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Be sure your connected to the RBS and not the RBR. You need to disable the wifi radio on your device, then go near the RBS, 4-6 feet. Then enable the wifi radio on the device. This will ensure it's connected to the RBS.
- steve04KUJan 28, 2020Aspirant
I will report back later this evening when I get home. Thank you.
- FURRYe38Jan 28, 2020Guru - Experienced User
:smileyhappy:
2.5.1.8
Modem:Spectrum brand?
E31T2V1
Router:
Askey Wave 2
RAK2V1K
What is the Mfr and model# of the ethernet switch in the configuration??
What is the size of your home? Sq Ft?3400
30-40 feet
1/48
Any Wifi Neighbors near by? If so, how many?0
Already enabled.
Fast roaming disabled causes connection isssues. Otherwise I disabled IPv6. The rest were already off.
