steve04KU
Jan 28, 2020Aspirant
ORBI RBR50 w/ 2 RBS50 Satellite issues:
I have an Orbi RBR50 daisy-chained with 2 RBS50 satellites. Neither satellite is connected by ethernet cable. Only wifi. Connections from the Router to Satellites are 5G and GOOD. Is it normal that w...
- Jan 29, 2020
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATAlso having wifi signal broadcast from modem can cause interference issues as well.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopPlease disable ALL wifi radios on the upstream router...Give one of the above suggestions a try.
steve04KU
I will report back later this evening when I get home. Thank you.
Jan 28, 2020Guru - Experienced User
:smileyhappy:
- steve04KUJan 28, 2020Aspirant
2.5.1.8
Modem:Spectrum brand?
E31T2V1
Router:
Askey Wave 2
RAK2V1K
What is the Mfr and model# of the ethernet switch in the configuration??
What is the size of your home? Sq Ft?3400
30-40 feet
1/48
Any Wifi Neighbors near by? If so, how many?0
Already enabled.
Armor, Circle, Daisy Chain needs disabling for ethernet connected RBSs, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Fast roaming disabled causes connection isssues. Otherwise I disabled IPv6. The rest were already off.- steve04KUJan 28, 2020Aspirant
I am getting 234mbps at the router. 110-ish at the satellites. Basically half at the satellites with 5G connections and good backhaul status.
- FURRYe38Jan 29, 2020Guru - Experienced User
steve04KU wrote:What Firmware is currently loaded?
2.5.1.8
E31T2V1
Router:
Askey Wave 2
RAK2V1K
Is the RBR working in AP mode or router mode? I see you have a router already in front of the RBR...
What is the Mfr and model# of the ethernet switch in the configuration?Any network switches in between the RBR and RBS or is the RBSs directly connected to the RBR?
What kind of LAN cable are you using to connect the RBS to the RBR? CAT6?
30-40 feet
1/48
Already enabled.
Fast roaming disabled causes connection isssues. Otherwise I disabled IPv6. The rest were already off.- steve04KUJan 29, 2020AspirantOrbi is in router mode. Recently got a new Spectrum setup although these issues existed prior. The Spectrum router is broadcasting a signal but nothing is connected to it. Again, prior to this equipment I had no router between and had same slowness issues at satellite.
RBS are connected to RBR by 5G signal. No hardwire. I suspect this may be the issue and could be considered normal? That’s what I need answered. Why are my SAT speeds 1/2 than the speed at the router (wirelessly).
