Reb8s
Dec 22, 2020Aspirant
Orbi rbr50 w/ 5 satellites going down the tubes on speed.
i have 5 sattelites to cover my 1 story 4000 squarfoot home on 3 acres. i have half gig service which if i plug in any other non netgear router into my modem i get near full speed every time (i eve...
Dec 22, 2020Guru - Experienced User
Wow, for that size of home and sq ft on one level, thats too many RBS. RBR50 and 1 RBS covers my 2story 5000sq ft home with basement without any problems.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Lets remove the RBS20 and RBW30 and just run the RBR50, RBS50 and the outside RBSY for now...
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Is Circle or Armor enabled?
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- Reb8sJan 02, 2021AspirantThanks for comments... tried and no improvement.
A) took off a few satellites. No change and blind spots in my coverage
B) could be that my house has a lot of tile, glass, and cement siding which could inhibit signal vs other materials.
C) used 30ft rule and adjusted layouts vs line of site, more blindspots
D) full reset. Speed on stats moved from 100m/full to 1000m/full but at additon of 3rd satellite dropped to 100m
E) manipulated channels and no performance improvement.
I'm still at a bit of loss. Still open to suggestions.- FURRYe38Jan 02, 2021Guru - Experienced User
Is Daisy Chain enabled?
- Reb8sJan 02, 2021AspirantYep. Daisychain is enabled. House is a big "L" router is at the corner and is more than 50 ft to the end of each point then there is the iot in the yard for gardening
What wifi channels are you using?
- Reb8sJan 02, 2021AspirantAlso... armor is not enabled
- vajimJan 02, 2021Master
With that size of your home my first question would be, where is the router located? A more centralized location would be better.
As superior as the Orbi Mesh system is, it's still a router/WiFi system and for the most part is not able to create new WiFi signals or strength. Where it does do a great job directing the flow of data, the distance between router and satellite can still be a challenge
