Reb8s
Dec 22, 2020Aspirant
Orbi rbr50 w/ 5 satellites going down the tubes on speed.
i have 5 sattelites to cover my 1 story 4000 squarfoot home on 3 acres. i have half gig service which if i plug in any other non netgear router into my modem i get near full speed every time (i eve...
Reb8s
Jan 02, 2021Aspirant
Also... armor is not enabled
vajim
Jan 02, 2021Master
With that size of your home my first question would be, where is the router located? A more centralized location would be better.
As superior as the Orbi Mesh system is, it's still a router/WiFi system and for the most part is not able to create new WiFi signals or strength. Where it does do a great job directing the flow of data, the distance between router and satellite can still be a challenge
