jeraboom
Oct 24, 2020Star
Orbi RBR50 web interface firmware upgrade screen has multiple entries for same satellite.
See attached image - firmware upgrade screen seems to have gone crazy. I've rebooted everything and it continues to display like this. Everything is working, but this is very annoying.
Does it happen with any browser?
Be sure to clear all browser caches...
Yes, all browsers (even on different machines).
No I haven't done a factory reset - I was trying to avoid that as I have a bit of a complex setup.
It maybe needed to clear this...also others have mentioned having problems with v4 FW so you may want to revert back to v16. NG is looking into v4 and v70 problems.
