JMFarnum
Mar 09, 2020Aspirant
Orbi RBR50 White flashing light
I have the White flashing light that many others on here seem to have. I can't get to the internet to update the Firmware that's been described by others. I hold the reset button for a long period o...
Mar 09, 2020Guru - Experienced User
Your modem already has a built in router and wifi. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would check on getting the Modem into bridge mode if possible.
Press the reset button on the back of the RBR for 15 seconds then release. The top ring LED should blink WHITE for about a minute, then it should change to slowly pulsating ON and OFF. Does this happen?
Just connect the laptop to the RBR using the ethernet connection temporarily while you attempt to get the RBR setup. Let us now if you can access the RBRs web page at 192.168.1.1 using the wire connected laptop. You'll eventually get the laptop connected via wireless, if we can get the RBR setup correctly or determine if the RBR is fautly.
JMFarnum
I don't believe I have a Double Nat situ.
My Coax from my ISP comes into the house and is plugged into the ARRIS modem they supplied.
I then plug an ethernet cable from the ARRIS directly to the Orbi RBR50.
We then connect all WiFi devices to the Orbi network.
I can't access my Orbi even with the ethernet cable from my laptop. unless im just looking in the wrong spot for it.
It might be a lost cause.
Pisses me off that I spent of $300 for this and it craps the bed 2 months after warranty.
