JMFarnum
Mar 09, 2020Aspirant
Orbi RBR50 White flashing light
I have the White flashing light that many others on here seem to have. I can't get to the internet to update the Firmware that's been described by others. I hold the reset button for a long period o...
JMFarnum
The amber light next t the power plug never appears when resetting.
Mar 09, 2020Guru - Experienced User
Look at the top ring LED. Does it blink WHITE then Slowly pulsate WHITE after pressing the reset button?
The model model you have does have a built in router and wifi:
https://arris.secure.force.com/consumers/ConsumerProductDetail?p=a0ha000000NJnzJAAT
I would get with your ISP and have them bridge this modem if possible. Just need to ensure that the modem isn't interfering with getting the RBR connected here.
Or try one of the other suggestions...
