JMFarnum
Mar 09, 2020Aspirant
Orbi RBR50 White flashing light
I have the White flashing light that many others on here seem to have. I can't get to the internet to update the Firmware that's been described by others. I hold the reset button for a long period o...
JMFarnum
I don't believe I have a Double Nat situ.
My Coax from my ISP comes into the house and is plugged into the ARRIS modem they supplied.
I then plug an ethernet cable from the ARRIS directly to the Orbi RBR50.
We then connect all WiFi devices to the Orbi network.
I can't access my Orbi even with the ethernet cable from my laptop. unless im just looking in the wrong spot for it.
It might be a lost cause.
Pisses me off that I spent of $300 for this and it craps the bed 2 months after warranty.
Retired_Member
Mar 09, 2020
JMFarnum wrote:I don't believe I have a Double Nat situ.
What changed? If it did work, what changed in your network? FW, new device?
