audrajhust
Oct 12, 2018Follower
Orbi RBR50 wifi connection not working and sending 404 - not found message
We have an Orbi RBR50 that I purchased and installed to create a stronger wifi network for streaming and multiple device usage. The only device it will let connect to it properly is my MAC and even t...
tucsontico
Oct 13, 2018Virtuoso
Please tell us more about your setup, i.e., what firmware is your ORBI running, what channels are you on for WiFi, what internet provider equipment do you have and how is it connected to your ORBI, etc.? The information in your original post is not enough to suggest any troubleshooting process other than to reset the ORBI to factory defaults, reload the currrent firmware and manually reconfigure it.
