audrajhust
Oct 12, 2018Follower
Orbi RBR50 wifi connection not working and sending 404 - not found message
We have an Orbi RBR50 that I purchased and installed to create a stronger wifi network for streaming and multiple device usage. The only device it will let connect to it properly is my MAC and even t...
Oct 13, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
VicMan
Jan 18, 2019Aspirant
I experienced the same problem, Netflix was not working and some 404 in web browsing, I just disable daisy chain and now everything is working fine
- ekhalilJan 19, 2019Master
It's very strange that Daisy Chain has anything to do with this issue. Can it be that the reboot accompanying the change of the Daisy Chain setting was what really solved your issue? If that is the case then you might get the same issue again later....I'd look at "double router" setup when I see such an issue at browsing (404 not found).
- VicManJan 27, 2019Aspirant
I know that the purpose of Daisy Chain should not affect a single configuration of 1router-1satellite, but 1 week later everything is working fine .
maybe the cause could be the congestion of many WiFi in the neighborhood is almost impossible to find an empty channel
- FURRYe38Jan 19, 2019Guru - Experienced User
When you disabled Daisy Chain, did you remove the check mark from the check box from Daisy Chain in the routers UI?
Also you can set up different DNS addresses as well on the Orbi router, I use .1.1.1.1 and 9.9.9.9
