audrajhust
Oct 12, 2018Follower
Orbi RBR50 wifi connection not working and sending 404 - not found message
We have an Orbi RBR50 that I purchased and installed to create a stronger wifi network for streaming and multiple device usage. The only device it will let connect to it properly is my MAC and even t...
jdtx120
Jan 23, 2019Aspirant
tcl tv gpkeeps disconnecting from orbi wifi.
- FURRYe38Jan 24, 2019Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.Whats the distance from the TV to the Orbi router or nearest satellite?
What WPA security modes are you using?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- FURRYe38Jan 28, 2019Guru - Experienced User
- lepackMar 11, 2019AspirantWent through the same disappointment with my Orbi. It just started throwing 404s and not allowing connection to many devices. Factory reset made it come back to life but frustrating to see that this issue hasn’t been resolved/addressed.
- FURRYe38Mar 12, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?There is newer FW available.
