Pypeke
Jan 06, 2020Aspirant
Orbi RBR50 wifi disconnections
After installing the Orbi RBR50 in July 2019, I began to notice dropped wifi connections every once in a while. When I called Netgear, they helped me fix it. The problems came back in a few months. I...
Pypeke
Also, I am using WPA2-PSK [AES] security settings. IPv6 is disabled.
- ShahabApr 21, 2020ApprenticeHi, Are you still experiencing the same issues?
- FURRYe38Apr 21, 2020Guru - Experienced User
Have you tried the new v16 FW yet?
Also you can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
You can revert back to stock FW if it doesn't work out for you.
