sicraze
Feb 04, 2020Aspirant
Orbi RBR50 Wifi Problems
Hi there. I have an Orbi RBR50 connected to a satellite and the wifi signal keeps dropping and I think it may be due to my set up. I have a white BT Openreach 061513 fibre modem connected to a Netgea...
Feb 04, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
sicraze wrote:Hi there. I have an Orbi RBR50 connected to a satellite and the wifi signal keeps dropping and I think it may be due to my set up. I have a white BT Openreach 061513 fibre modem connected to a Netgear R7000 Nighthawk Router. My Netgear Orbi Router is then connected to my R7000 in access point mode. When I look for wifi networks both my Orbi network and Netgear R7000 come up separately. The Netgear R7000 wifi is fine. Does this mean they are competing and could this be the reason why the Orbi network keeps dropping? The Orbi router and R7000 are also right next to eachother. Both routers have the latest firmware installed. Thanks.
