MTS99
Oct 21, 2019Aspirant
Orbi RBR50 WIFI unavailable
My orbi 50 recently lost connection to the internet. I tried to connect via the orbi app and it was not able to find the router. Tried rebooting with the same result. Tried to reconfigure but coul...
Oct 21, 2019Guru - Experienced User
Is the power light on the orbi on? What is it doing? color/blinking/solid
When you reboot the router, does the light on the top do anything? if so what? color/blinking/solid
I know this sounds stupid but many thing that if you just quickly hit the reset, it works. Did you hold the reset button, while powered on, for 7-10 seconds or until the lights change?
Have you tried hard wiring into the orbi and attempting to log into it?
- MTS99Oct 21, 2019Aspirant
The power light is on and the ring light is pulsing white. The satellite units are pulsing red. When I reboot the unit goes to the pulsating white light. The first thing I tried was to just reboot, and then I reset the unit to factory settings. I haven’t tried hardwiring to the router. I give it a try.
- SW_Oct 21, 2019Prodigy
MTS99 wrote:The power light is on and the ring light is pulsing white. The satellite units are pulsing red. When I reboot the unit goes to the pulsating white light. The first thing I tried was to just reboot, and then I reset the unit to factory settings. I haven’t tried hardwiring to the router. I give it a try.
Satellite and router ring LEDs
- Pulsing white. Your Orbi router and satellite are applying a configuration or updating their firmware.
- OFF. Your Orbi router and satellite are working normally.
Be patient...(?)
