MTS99
Oct 21, 2019Aspirant
Orbi RBR50 WIFI unavailable
My orbi 50 recently lost connection to the internet. I tried to connect via the orbi app and it was not able to find the router. Tried rebooting with the same result. Tried to reconfigure but coul...
Oct 21, 2019Guru - Experienced User
Is the power light on the orbi on? What is it doing? color/blinking/solid
When you reboot the router, does the light on the top do anything? if so what? color/blinking/solid
I know this sounds stupid but many thing that if you just quickly hit the reset, it works. Did you hold the reset button, while powered on, for 7-10 seconds or until the lights change?
Have you tried hard wiring into the orbi and attempting to log into it?
MTS99
The power light is on and the ring light is pulsing white. The satellite units are pulsing red. When I reboot the unit goes to the pulsating white light. The first thing I tried was to just reboot, and then I reset the unit to factory settings. I haven’t tried hardwiring to the router. I give it a try.
- SW_Oct 21, 2019Prodigy
MTS99 wrote:The power light is on and the ring light is pulsing white. The satellite units are pulsing red. When I reboot the unit goes to the pulsating white light. The first thing I tried was to just reboot, and then I reset the unit to factory settings. I haven’t tried hardwiring to the router. I give it a try.
Satellite and router ring LEDs
- Pulsing white. Your Orbi router and satellite are applying a configuration or updating their firmware.
- OFF. Your Orbi router and satellite are working normally.
Be patient...(?)
