Djshuh's avatar
Djshuh
Orbi RBR50 Will Not Factory Reset
Hi, So I have a problem with my Orbi RBR50!  Factory Reset doesn't work. I try to press the reset button 10 seconds also 30 seconds but without change, Power LED  also green color, not orange. In RB...
  • Mstrbig's avatar
    Mstrbig
    Sep 02, 2020
    Djshuh wrote:
    I did all these actions. Power LED color green but same my RBR50 doesn't work. No internet connection no WiFi also I can't connect in my device.After you factory reset, did you load the app and re-configure the RBR50? It needs to be reinstalled after reset.
