HighTide
Aug 17, 2018Follower
ORBI RBR50 will not recognize internet source cable from modem
Orbi was working great (have two satellites inside and just bought the outdoor sat for the poolhouse). We had a bad lightning strike near our home last night. I have gone through all sorts of reset...
Aug 18, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
Has a factory reset been performed on Orbi system and set up from scratch?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
