truprecht
Aug 12, 2019Guide
Orbi RBR50 will not work with new Spectrum modem
We have had an Orbi RBR50/RBS50 working with a Spectrum modem/router for 2 years. We've recently had some problems with internet connectivity going down intermittently. We called Spectrum, who dec...
- Aug 12, 2019
OK, it's fixed. Connected to Modem. Followed the "new setup" instructions in the app, and it booted up fine. I swear I did that no fewer than 3 times yesterday, but today it's working. Thanks for the repsonses.
Aug 12, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so,
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Power OFF both ISP modem and RBR for 1 minute. Then power On the modem, after it syncs, power on the RBR...
- truprechtAug 12, 2019Guide
The old Spectrum device which worked fine for 2 years was a combination modem/router. (We never connected to the Orbi via ethernet, only WiFi, so I don't know if it was configured as a router or access point.) The new Spectrum hardware is separate modem and router devices.
- FURRYe38Aug 12, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Would need this information so we can help you determine a course of action...
- Retired_MemberAug 12, 2019
truprecht wrote:The old Spectrum device which worked fine for 2 years was a combination modem/router. (We never connected to the Orbi via ethernet, only WiFi, so I don't know if it was configured as a router or access point.) The new Spectrum hardware is separate modem and router devices.
Did you tell Spectrum you already have a router?
if they insist you use their router, then either the Orbi or the Spectrum router will have to configured in the AP mode. The old Spectrum device worked fine with the Orbi because somewhere in your network one of those routers was in AP mode.
- CrimpOnAug 12, 2019Guru - Experienced User
If the Orbi is configured as an access point (AP), then it is waiting for "the router" to assign it an IP address, and there is no router. As an AP, the only settings the Orbi has are WiFi name and password.
This should get you working.
If the Orbi is configured as AP, shouldn't it work when connected to the Spectrum router? (router, not modem). It isn't.
I'm not in front of the hardware now, so I'll try some of the above recommendations and provide the ISP modem model info when I get home tonight.
Firmware version is V2.3.1.44
Spectrum-provided modem is manufactured by Hitron Technologies, model number is E31N2V1.
I have tried to access the Orbi configuration by connecting an ethernet cable from the internet port on the Orbi to my laptop, opening a browser and connecting to orbilogin.com, but it just puts me in an endless loop asking for login/password and saying the connection is not private.
I can connect via the iPhone app, version 2.4.2.4...
- Retired_MemberAug 13, 2019
truprecht wrote:OK, it's fixed. Connected to Modem. Followed the "new setup" instructions in the app, and it booted up fine. I swear I did that no fewer than 3 times yesterday, but today it's working. Thanks for the repsonses.
Nice job....are you still using the Spectrum router?
- FURRYe38Aug 13, 2019Guru - Experienced User
Thank for confirming the modem information. The modem is a modem only so no built in router here. FYI, this modem has a Puma 7 chip set and there are known issues with this chip set. You may want to move to a broadcom chipset modem at some point.
Glad you go the Orbi system setup.
Enjoy.
truprecht wrote:Firmware version is V2.3.1.44
