Chill25769's avatar
Chill25769
Follower
Jan 15, 2023
ORBI RBR50 Wired Satellite not showing on iPhone 16.2 Orbi App
ORBI RBR50 Wired Satellite not showing on iPhone 16.2 Orbi App but the satellite does show with devices connected to it when I connect via the web browser
1 Reply
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello Chill25769,
    Welcome to the NETGEAR Community!
    I understand that you are not able to see the satellite connected via ethernet on your Orbi app using iOS V16.2.
    Please ensure that you are using the Orbi app version 2.22.0.247. To verify your Orbi app version please navigate to the app store and then type Orbi in the search section. If you are not on the current version It will prompt you to update to the latest version available.
    Best,
    Kevin
    Community Team
