CDR-NJ
May 13, 2020Tutor
Orbi RBR50 Wired Satellite Outdoor
Hello, I'm hapily using a RBR50 and RBS50 with a wired backhaul to cover 3 levels of my home and "decent" outdoor coverare too. I want to improve the outdoor wifi signal for a greenhouse and pool ar...
May 13, 2020Guru - Experienced User
NG only has a RBS50Y thats is there out door Satellite system. I don't believe it's wire supporting. Check the spec sheet to be sure....
CDR-NJ
May 13, 2020Tutor
thanks i'm aware of the outdoor orbi its wireless only which doesnt help much. I'm looking for something easy and wired vs a build my own solution.
- CDR-NJMay 13, 2020Tutor
By the way, a outdoor orbi that was POE powered would be a kick-butt solution, as would an indoor satellite. Most modern / new home installs would drool for this.
