CDR-NJ
May 13, 2020Tutor
Orbi RBR50 Wired Satellite Outdoor
Hello, I'm hapily using a RBR50 and RBS50 with a wired backhaul to cover 3 levels of my home and "decent" outdoor coverare too. I want to improve the outdoor wifi signal for a greenhouse and pool ar...
JudeMills
Oct 09, 2020Tutor
I also would like to use an Orbi Satellite inside a greenhouse with the same temp and humidity factors and wondering if the RBS50 could withstand the rigors. I need to connect an POE Lorex camera to it, so the RBS50Y won't work since it doesn't not have any connectivity features. Netgear REALLY needs to make a tough outdoor satellite that has POE/jacks in it!!!
