Timberbull's avatar
Timberbull
ORBI RBR50 wired with cat7 to RBS50 300 feet away
I have a fiber modem entry connected to an RBR50 in downstairs of my home.  It is wired with cat6 to an RBS50 upstairs, with a second non-wired RBS50 30 feet away in the upstairs.  This provides appr...
  • FURRYe38's avatar
    May 31, 2022
    Yes that should work. Be sure to check the CAT# vs recommended cable max length distance.
    Timberbull wrote:
    I have a fiber modem entry connected to an RBR50 in downstairs of my home.  It is wired with cat6 to an RBS50 upstairs, with a second non-wired RBS50 30 feet away in the upstairs.  This provides approx 75 of exterior wifi to exterior of house.  I need to add wifi to the shop and have conduit from modem area to shop 250 feet away.  Can I use Cat7 for the longer run in conduit and use RBS50 as hard wired connection point in shop?  Cat 7 would be connected from RBR50 downstairs to shop RBS50 with cat7 approx 275 feet.
