Timberbull
May 31, 2022Aspirant
ORBI RBR50 wired with cat7 to RBS50 300 feet away
I have a fiber modem entry connected to an RBR50 in downstairs of my home. It is wired with cat6 to an RBS50 upstairs, with a second non-wired RBS50 30 feet away in the upstairs. This provides appr...
- May 31, 2022
Yes that should work. Be sure to check the CAT# vs recommended cable max length distance.
Timberbull wrote:
I have a fiber modem entry connected to an RBR50 in downstairs of my home. It is wired with cat6 to an RBS50 upstairs, with a second non-wired RBS50 30 feet away in the upstairs. This provides approx 75 of exterior wifi to exterior of house. I need to add wifi to the shop and have conduit from modem area to shop 250 feet away. Can I use Cat7 for the longer run in conduit and use RBS50 as hard wired connection point in shop? Cat 7 would be connected from RBR50 downstairs to shop RBS50 with cat7 approx 275 feet.
May 31, 2022Guru - Experienced User
