Arman1973
Aug 28, 2019Aspirant
Orbi RBR50 with Bell Home Hub 3000
Hello all, I just got RBR50 model and i have a Bell Home hub 3000 modem/router with 1gb service. In the back of my modem i have a WAN port, do i connect the Orbi to that port or any of the LAN port...
Aug 28, 2019Guru - Experienced User
Yes, connec the Yellow WAN port the one of the free open LAN ports on your MODEM/Router.
FYI, Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
Arman1973 wrote:Hello all,
In the back of my modem i have a WAN port, do i connect the Orbi to that port or any of the LAN ports?
- Arman1973Aug 28, 2019Aspirant
Do i have to disable the WPS also? I just want the Hub 3000 act as a modem and Orbi take care of the rest.
Thanks for your fast reply
- FURRYe38Aug 28, 2019Guru - Experienced User
ALL Wifi on the ISP Modem should be fully turn off.
Contact the ISP to help you configure the ISP modem for modem only mode.
Try the other suggestions if modem mode can't be done.
- Retired_MemberAug 28, 2019
FURRYe38 wrote:
This would be a double NAT condition which isn't recommended.IMHO....NG should state this as..."This would be a double NAT condition and unless your ISP requires use of their modem/router combo, it is strongly discouraged."
