Arman1973
Aug 28, 2019Aspirant
Orbi RBR50 with Bell Home Hub 3000
Hello all, I just got RBR50 model and i have a Bell Home hub 3000 modem/router with 1gb service. In the back of my modem i have a WAN port, do i connect the Orbi to that port or any of the LAN port...
Arman1973
Do i have to disable the WPS also? I just want the Hub 3000 act as a modem and Orbi take care of the rest.
Thanks for your fast reply
Aug 28, 2019Guru - Experienced User
ALL Wifi on the ISP Modem should be fully turn off.
Contact the ISP to help you configure the ISP modem for modem only mode.
Try the other suggestions if modem mode can't be done.
