claireb707
Sep 10, 2021Aspirant
Orbi rbr50 with netgear switch GS608 switch
Just bought the Orbi with satellite, got it up and running ok however my switch has now stopped working. the Orbi app can see the devices using the switch but there is no internet getting through to...
- Sep 10, 2021
hmmm maybe its not the switch.... Ive plugged one direct into the router and its still not working there either...
Found it... I had a cable plugged both ends into the switch :womanfrustrated: doh
claireb707
thanks, will try that now...
claireb707
- claireb707Sep 10, 2021Aspirant
oddly i hadnt changed any cables on the switch, they were all exactly as they were with the old router
- FURRYe38Sep 10, 2021Guru - Experienced User
That would do it. :smileywink:
Glad you found it.
Please mark your thread as solved so others will know.
Enjoy.
