urushi
Sep 09, 2022Follower
Orbi RBR50 with ONT Cox internet
I previously had an RBR50 v1 with one satellite connected wirelessly with Verizon fios ONT at my previous apartment. I never had a single problem. I have moved and now have cox communication ONT. My n...
Sep 09, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How are the RBS connected to the RBR via ethernet? Directly to the back of the RBR or is there a LAN switch in between them?
What CAT# lan cable are you using? CAT6 is recommended.
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Too Much Wifi: https://youtu.be/UR0viMLISz4
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
