Kakaroth75
Nov 19, 2024Aspirant
ORBI RBR50 with RBS50 capped lan speed
Hello to all!
I just upgraded my connection with 2.5Gbps fiber, and i know i will use only 1Gbps since LAN ports are GbE.
However, I have a tricky issue with speed on a RBS50 satellite connected with cable to router RBR50.
I connect my desktop to satellite with LAN cable so i should have full wired solution from external modem, router and satellite.
The problem is that download speed seems CAPPED at 200Mbps while upload speed is over 950Mbps.
Really don't know why!
Tried some tips form this forum but no results.
I changed cables to check, no ipv6, no other ideas.
If someone have a clue i will appreciate!! 🙂
Thank you in advance guys!
Sorry to all guys i found issue.
Not in ORBI products but tricky settings on my eth port on ASUS motherboard.
If moderators wants to kee this post alive maybe can help others understand solution for this speed CAP.
I'm, not sure if i can put extrnal link.
However this topic on INTEL forum tells you how to manage those strange speed caps.
Maybe will be a more frequent issue with all these fast fiber connections available.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - Kakaroth75Aspirant
