DEGB
Nov 09, 2020Aspirant
Orbi RBR50 with Setellite
I have an Arris NVG589 Uverse Gateway for TV, Internet and phone. I have connected my Orbi RBR50 router to the gateway as an access point for my home Wi-Fi with wireless connection to the Satellite. ...
Nov 09, 2020Guru - Experienced User
Is the RBS wirelessly connected to the RBR?
Do other wired devices get internet services thru the RBS?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected
Being that the RBR is in AP mode, if it is, then the modems router will and should be passing internet services thru the RBR and to the RBS.
- DEGBNov 09, 2020AspirantRe: Orbi RBR50 with Setellite
V2.5.1.16Is the RBS wirelessly connected to the RBR?
Yes
Yes
35-40 ft
- FURRYe38Nov 09, 2020Guru - Experienced User
I would check the IP address networking settings on the Sony device. Sounds like the device isn't get up correctly for networking.
