deltabravoh
Aug 03, 2017Aspirant
Orbi RBR50 with two RBS50 disconnects
I've updated to latest firmware and did a factory reset. Do I need to switch to AP mode as well? If this doesn't work I'm returning it. the last two months of disconnects, at the worst time too, are e...
deltabravoh
Aug 07, 2017Aspirant
It's appears to be at random times.
DarrenM
Aug 08, 2017Sr. NETGEAR Moderator
I would make sure MuMimo and beamforming are enabled under the Advanced setup-Wireless settings.
DarrenM
- deltabravohAug 08, 2017AspirantOk I'm enabling both now. 3 disconnects today that I know about.i have latest firmware I have performed factory resets, re syncd etc.
We will see. - deltabravohAug 09, 2017AspirantMultiple disconnects today. I have reset both the router and the satellites at least three times I have turned on beamforming and the other thing I am in ap mode.
Yet it continues to disconnect I suspect now it must be the hardware. If you send me a new router and two satellites I will send you back these pieces of crap. This is entirely taking too much work and wasting time with these disconnects.
Are they all source from the same place I suspect not since I must've done the crap batch.- DarrenMAug 11, 2017Sr. NETGEAR Moderator
Hello deltabravoh
I sent you a PM.
DarrenM
- Lmj107Sep 17, 2017Initiate
I am also having the disconnect issue. Multiple times today and it's so frustrating. I just enabled beamforming and mumino to see if that helps. Installed v2.0.0.72 the other day and that did not help.
