Net12148
Aug 19, 2021Follower
Orbi RbR50 won't connect to Bell Hub 2000
I am trying to connect my Orbi router to a Bell Hub 2000. I have put the Hub in DMZ mode and turned off the wifi but I continue to get a purpose light on the Orbi.
michaelkenward
Aug 20, 2021Guru - Experienced User
Is that this?
Home Hub 2000 - support, help and troubleshooting from Bell Internet
That puts you in this territory:
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
You could see if this yields anything useful:
bell hub 2000 bridge mode - Google Search – bell hub 2000 bridge mode
A lot of Orbi users happily put their router into wireless access point mode.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
