notatweak
May 13, 2019Aspirant
Orbi RBR50 won't let me update apps
May 13, 2019Guru - Experienced User
Apps as in?
notatweak
May 14, 2019Aspirant
Sorry, Firmware. I can't log in to the device so it won't update firmware.
- FURRYe38May 14, 2019Guru - Experienced User
Try a factory reset with the RBR and use a wired PC and web browser connected to the RBR and walk thru the setup wizard. Then check FW updates using the RBRs web page.
