notatweak
May 13, 2019Aspirant
Orbi RBR50 won't let me update apps
SteffanH
May 18, 2019Aspirant
I’m having the same problem with apps and os updates not working.
- ekhalilMay 18, 2019Master
If you have issues with certain devices or apps not reaching internet or specific sites, the first thing I would suspect is double NAT.
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (traceroute 8.8.8.8 if you're using a Mac computer)
- If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
- If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the root cause of the issue,
