Flo_Amsterdam
Dec 19, 2023Aspirant
orbi rbr50 wont reset
HELP om losing it, almost smashing my orbi through the house... one moment everything is fine, next moment no internet connection... i've tried every possible way to reset the orbi router, but it ...
Dec 19, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Can you access the RBRs web page at 192.168.1.1 with a ethernet connected PC and web browser after pressing the reset button for 15 seconds then release. Try this with the RBR disconnected from the ISP modem/ONT.
- Flo_AmsterdamDec 19, 2023Aspirant
where can I find what version its on?
it has been working fine for the last 2 years with cat6
i dont even know if there was n update, one moment it was online, was about to play xbox, and then the next sec it was offline, and wont come back online...
just had everything off, then turned on the modum and waited to be fully operational.
then plugged in the orbi, nothing, just flashes white ring on top....
tried to reach the page but can't.... says i have no conection
i pulled the cable from the orbi, and put it directly into my pc, and then the pc has internet....
so everything is working, but somehow the rbr50 doesnt allow the connection....
- FURRYe38Dec 19, 2023Guru - Experienced User
If you can get into the RBRs web page will be seen on the upper right hand corner of the page.
