Flo_Amsterdam
Dec 19, 2023Aspirant
orbi rbr50 wont reset
HELP om losing it, almost smashing my orbi through the house... one moment everything is fine, next moment no internet connection... i've tried every possible way to reset the orbi router, but it ...
Flo_Amsterdam
where can I find what version its on?
it has been working fine for the last 2 years with cat6
i dont even know if there was n update, one moment it was online, was about to play xbox, and then the next sec it was offline, and wont come back online...
just had everything off, then turned on the modum and waited to be fully operational.
then plugged in the orbi, nothing, just flashes white ring on top....
tried to reach the page but can't.... says i have no conection
Flo_Amsterdam
i pulled the cable from the orbi, and put it directly into my pc, and then the pc has internet....
so everything is working, but somehow the rbr50 doesnt allow the connection....
