donalcombright
Oct 15, 2021Guide
Orbi RBR50 Working Strange?
So I have an Orbi setup with 2 satellites. My "office" location satellite seems to act "off." Despite showing under Attached Devices fine (Backhaul Status GOOD) Browsing attached devices however ...
donalcombright
Oct 15, 2021Guide
FURRYe38 , all sats and router are on V2.7.3.22.
Home is roughly 2900sq feet. Sat 1 is about 45' away in the garage. Router is in center of home and sat 2 is roughly 20' away. Both sats are hardwired though, so not sure that matters right? All are on the same level of the house (ground floor).
Oct 15, 2021Guru - Experienced User
20 feet is too close, wired or wireless.
Are the RBS directly connected to the back of the RBR or is there a LAN switch in between?
- donalcombrightOct 15, 2021GuideSo having the satellite less than 30’ would cause those issues? That doesn’t seem to make much sense. It also worked seemingly fine for 4 months until recently.
I have a switch between the router and sats, the same switch for both.- FURRYe38Oct 15, 2021Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
- donalcombrightOct 15, 2021GuideNetgear GS316. Also, thank you.
