golfhacker57
Dec 07, 2017Aspirant
Orbi RBR50
I recently switched ISP from ATT to Cox and also got a Linksys CM3024 modem. Prior to switching to Cox and getting the new modem, I was able to view my Q-See QTH85 cameras outside of my LAN. I no l...
DarrenM
Dec 11, 2017Sr. NETGEAR Moderator
Did you bridge the new modem to be only a modem?
DarrenM
golfhacker57
Dec 11, 2017Aspirant
The new modem is strictly a modem and not a router/wifi. It is a Linksys CM3024.
- DarrenMDec 12, 2017Sr. NETGEAR Moderator
They could be ports blocked by your ISP have you checked with COX?
DarrenM- golfhacker57Dec 12, 2017Aspirant
Cox does not block port 85. I was able to fix it by doing the following on port forwarding.
When setting up port forwarding the external port is 8080 while the internal port is 85 and the internal ip address assigned to the cameras.
