Kathie55's avatar
Kathie55
ORBI RBR50
My devices do not recognize my password.  I probably typed a wrong key.  How do I correct?
  • Kathie55's avatar
    Kathie55
    May 20, 2019
    It was in regard to the ORBI router.  I resolved the problem by tapping the reset button on the router, rebooting the modem, and finally following the installation instructions.  All went well.  Thank you for your concern.
