Moneypit
Jun 25, 2019Aspirant
Orbi Rbr50
Can anyone help me with this issue I currently have an Orbi rbr50 with one satellite which works well but when I recently installed a ring floodlight security camera to the network, I already had a...
Jun 25, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
What happens if you temporarily disable the 5Ghz SSID broadcast on the RBR and try the iphone again? Under Advanced Tab/Advanced Settings/Wireless Settings
- MoneypitJun 25, 2019Aspirant
FM is V2.3.1.60
Router is a Virgine Media Hub 3.0 380Mbt/40mbt Im in the UK
Orbi ia operating in Router mode
Home is 4000SqFt build with brick and cblock internal wallls
Satellite is hardwired and is ca 50 ft away from router.
Using Channel 1 but have swapped from 6 and 11.
Yes some neighbours around hence swapping channel
so I did disable the 20/40 MHz Coexistence
Disabled chaining
Enabled Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
Enable MU-MIMO
and the all seems to be working, so will have to see if it was the reboot of the router or whether it was the chaining, as i guess that was the issue I I had the satellite connected wirelessly but connectivity was up and down so hard wired it, i didnt dissable the chaining.
Thanks for the reply and the suggestions, I will monitor and slowly make the remaining changes to see if this makes any difference.
thanks again
- FURRYe38Jun 25, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
