Jshdlr10
Nov 05, 2019Aspirant
Orbi RBR50
Hey guys, I'm a complete newbie to all of this. I was looking for some help and clarity. Hoping someone can help. I'm hoping to cut as many ties possible with cable and renting equipment. I purc...
Jshdlr10
Thank you! That's what I figured, but wasn't sure. Is there any specific I should be looking for in a modem when purchasing?
Anonymous
Nov 05, 2019
Jshdlr10 wrote:Thank you! That's what I figured, but wasn't sure. Is there any specific I should be looking for in a modem when purchasing?
Your best bet is to call your Internet provider and ask for recommendations. If at all possible, stay away from modem/router combos. They will work, but in my opinion, not worth the headaches.
- michaelkenwardNov 06, 2019Guru - Experienced User
Very true. But from my experience you can't even guarantee the "they will work" bit.
As suggested, start with the ISP. But, not all ISPs will advise customers on the kit that will work on their networks. They want you to rent from them. Their experience of different brands may also be limited.
Start with the sort of Internet you have. DSL? Cable? Some sort of fibre? A satellite dish?
If your ISP has a user community, like this one, then you might get help there.
Or tell people here was USP iot is, There may be another user.
Then there are places like Amazon, which sometimes mention ISPs, and may have reviews that say what they are on.
- AnonymousNov 06, 2019
michaelkenward wrote:
Retired_Member wrote:If at all possible, stay away from modem/router combos. They will work, but in my opinion, not worth the headaches.
From my experience, I've been with Cox for years. Started out renting their modem and later bought my own. I believe Cox evens lists the modems that they recommend to work with with their network (for what it's worth) on their website.
I would never subscribe to an ISP that forced me to use their equipment that consisted of a modem/router combo.
- Jshdlr10Nov 06, 2019Aspirant
Thank you all for your input.
I have Xfiniity's highspeed which is DSL, I belive.
