lfd346
Feb 14, 2020Aspirant
Orbi RBR50
My Orbi keeps loosing connection. I thought this was fixed after the last firmware update but it has started again. Any help with this would be appreciated.
Feb 17, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Has a factory reset and setup from scratch been performed since last update?
- lfd346Feb 17, 2020Aspirant
Thanks for replying, nut for whatever reason my app said my system was disconnected. I was accessing from my mobile , but when i got home everthing was fine. reloaded my app and seems to be working? Thanks
- FURRYe38Feb 17, 2020Guru - Experienced User
Please give feedback to the question presented...maybe something going on with app as well.
