88keez
Mar 07, 2020Aspirant
Orbi RBR50
Purchased this Router with 2 satellites because of the area it needs to cover. However, the router and 1 satellite shows "green" where the 2nd satellite is "orange" - I can't get it to register "gre...
Mar 07, 2020Guru - Experienced User
- 88keezMar 08, 2020Aspirant
The modem is an Arris TG852 (Sparklight). The router and satellites are being used on the main level of a 4600 sq. ft. house. Router and one satellite are about 42' straight down a hall from each other and the second satellite is approx. 40 ft. from first satellite in an outside room. The 1st statellite to 2nd one goes through basically 2-3 walls (just wood & siding) to outside room. These are rated up to 7000 sq. ft. for shouldn't be having a problem.
- FURRYe38Mar 09, 2020Guru - Experienced User
What mode is the Arris modem/router working in? Bridged or Router mode. If in router mode, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI too have SparkLight, though not the same modem.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
88keez wrote:The modem is an Arris TG852 (Sparklight). The router and satellites are being used on the main level of a 4600 sq. ft. house. Router and one satellite are about 42' straight down a hall from each other and the second satellite is approx. 40 ft. from first satellite in an outside room. The 1st statellite to 2nd one goes through basically 2-3 walls (just wood & siding) to outside room. These are rated up to 7000 sq. ft. for shouldn't be having a problem.
- 88keezMar 09, 2020Aspirant
Unfortunately, you are speaking a language that I don't understand. Makes me think I need some kind of tech specialist, which isn't going to happen. It would be nice, if when you purchase a system, there are instructions to show the procedure. Very much appreciate your knowledge and attempt to help.
