dmccoy
Mar 25, 2020Tutor
ORBI RBR50
I've been having trouble with my ORBI RBR50 losing internet connection frequently (several times a week and sometimes multiple times a day). It has the latest firmware update (V2.5.1.8). I do not h...
Mar 25, 2020Guru - Experienced User
Do both wired and wireless connections go down?
Have you ask the ISP to reset there side connection hardware?
Has a factory reset and setup from scratch been performed since last FW update? You might give this a try with the RBR.
Don't enable any Circle or Armor features...
dmccoy
Mar 25, 2020Tutor
1. Just the wireless connections drop. Wired connections are fine.
2. I have not spoken to ISP yet due to #1.
3. At this moment, I am only showing one other wireless network available which shows as a hidden network. Occasionally, I will see a couple of other neghbor networks show up.
I have not tried the factory reset yet. That was going to be my last resort.
- FURRYe38Mar 26, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Try a factory reset and setup from scratch. v2.5.1.8 works well for me and others.
