dmccoy
Mar 25, 2020Tutor
ORBI RBR50
I've been having trouble with my ORBI RBR50 losing internet connection frequently (several times a week and sometimes multiple times a day). It has the latest firmware update (V2.5.1.8). I do not h...
dmccoy
Mar 25, 2020Tutor
1. Just the wireless connections drop. Wired connections are fine.
2. I have not spoken to ISP yet due to #1.
3. At this moment, I am only showing one other wireless network available which shows as a hidden network. Occasionally, I will see a couple of other neghbor networks show up.
I have not tried the factory reset yet. That was going to be my last resort.
Mar 26, 2020Guru - Experienced User
Try a factory reset and setup from scratch. v2.5.1.8 works well for me and others.
