dmccoy
Mar 25, 2020Tutor
ORBI RBR50
I've been having trouble with my ORBI RBR50 losing internet connection frequently (several times a week and sometimes multiple times a day). It has the latest firmware update (V2.5.1.8). I do not h...
Retired_Member
Mar 26, 2020
dmccoy wrote:I've been having trouble with my ORBI RBR50 losing internet connection frequently (several times a week and sometimes multiple times a day). It has the latest firmware update (V2.5.1.8). I do not have a modem and only one satellite. There is a straight connection into the router from my ISP. Any ideas/suggestions? TIA
here's your problem: V2.5.1.8
others meant to mention that
dmccoy
Mar 27, 2020Tutor
Here's another thing I totally forgot to mention. The router loses internet connection but the satellite does not. See attached screenshot.
- Retired_MemberMar 27, 2020
dmccoy wrote:
Here's another thing I totally forgot to mention. The router loses internet connection but the satellite does not. See attached screenshot.that looks like the app which I wouldn't trust
- FURRYe38Mar 27, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? It would be a good step to start to see if the RBR can be come stable. It's a valid trouble shooting step that needs to be tried.
Try a factory reset on the RBR and RBS and setup from scratch. Try some of the suggestions as well.
dmccoy wrote:
Here's another thing I totally forgot to mention. The router loses internet connection but the satellite does not. See attached screenshot.- Retired_MemberMar 27, 2020
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
dmccoy wrote:
Here's another thing I totally forgot to mention. The router loses internet connection but the satellite does not. See attached screenshot.Factory reset is NOT required.
A better FW is.
